Hello friends,
Kospet releases V3.0 for the Optimus Pro
http://bbs.kospet.com/forum.php?mod=viewthread&tid=38&extra=page%3D1
Does anybody knows what the improvements are?
Hopefully better battery life
Thanks a lot
Regards
Hello friends,
Thanks a lot
Regards
yep, the improvements are known:
Hi, After installing I found 2 problems that in Sound mode the ring volume is disabled … You can’t adjust the ring volume at all. and the another one is in long stand by mode the time is always on …Can anybody reply regarding camera rotation, I had also installed Hedgecam2… in this apps not able to rotate option…
You need to make a factory reset after flashing.
