When I start up the Kospet Optimus Pro, it attempts to load a watchface that is not compatible. The screen shows a looping circle that does not allow any actions. I need to get to file manager so I can delete the bad watchface. I have tried the swiping technique on start up, but no luck. Anyone have any other ideas on how to break out of this loop?
Thank you.
Ok, flashing the firmware will help for sure. But I think you should try to swipe to the side during the start some more time. Normaly it works, but you need a few more tries.
Thanks for the help. Flash solved the problem. What a drag, but grateful the flash worked. Another Christmas miracle.
Thank you
