Kospet Hope Wireless Update
Hello,
I’v receives the question if I want to update. After pressing yes there is a new screen with the tip to keep the watch on a power source. The only option visible in square screen is cancel. I assume the must be an Ok option to. How to proceed?
Sander
Try changing from square to round mode in the power menu
do you mean the option to change the display from round to square is gone
I have the same issue here. I tried with both round and square modes. But still its not visible.
I changed from square to round mode. But it is still hiding OK button inside the screen.
Pls. reply if you have any solution.
Must change screen DPI in developer options
What value I should mention to change the dpi…?
How to change to developer options? And what DPI?
Sander
you could also use Vysor, then you will be able to see the whole screen on your computer
Or
Thank you very much man… it worked.!
I change the dpi to 450, then I could find the OK button to process further.
Now my watch’s firmware is updated as latest.
