Kospet Hope not charging
Hello, my Kospet Hope is not charging, through the cable. Anyone can help? Thank you
Hi have you tried cleaning the charging pins ? Especially on the watch itself . Usually works after this . Thanks
what method would be best to clean the pins?
Small amount of alcohol should work .
thank you tim. i noticed today they need some scrubbing.
Let me know how you get on . Thanks
I cleaned it but with no result.
So it could be a faulty charger or battery inside has a poor connection .
Hello Tim.Thank you so much.
If you are feeling upto it you could open watch and see if battery connected . Be very carefull though
worked like a charm, now placing upon charger is back to working on the 1st to 3rd try. lol
Great news :+1::+1::+1::+1::+1:…
