With adapted power meter…
CREDIT: IWC.com
Hi, I have a question. The hand that shows the date. If the month is only 28 days old, will it move to the next day at number 1 or does it continue to move? Thank you
That hand (the date) moves from one day to the next. For February, it will move from 28 to 1 (March)
thank you, i will try
Please note that positioning the days of the month can be a little tricky. I do it by entering the 3 - 31 odd numbers first, then reducing the angle span a little and finally adding the number 1 in a new field positioned just to the right of the number 31.
In that way the days of the month rotation will line-up precisely with the correct day.
so it will be fun I’ll try it on the weekend
