it is possible flash firmware thor in les1?
and in this case, i check or uncheck the option “Preloader” in “flashtool”?
Jun 12, 2017 13:51:07 GMT 1 galaxy76 said:
it is possible flash firmware thor in les1?and in this case, i check or uncheck the option “Preloader” in “flashtool”?
perhaps…
You can flash just system.img and leave all the rest unchecked. I think the only difference is in that image file. This way you probably won’t even loose what you have already on the watch
ok. thank’s
Jun 13, 2017 7:59:51 GMT 1 galaxy76 said:
ok. thank's
Did you manage to flash THOR firmware into les1? If yes could you post here your results?
Best regards,
Padaka
I need different… I need to flash firmware for les1 in thor
firmware Z10-YFZ-V11-20180206 for lemfo les1
But I´m afraid to brick thor.
Mar 8, 2018 8:23:21 GMT 1 morpho said:
I need different.... I need to flash firmware for les1 in thorfirmware Z10-YFZ-V11-20180206 for lemfo les1
It is possible to do in Win10?
Or not?
Les1 have more cutie faces i guess.
Mar 9, 2018 6:30:20 GMT 1 morpho said:
It is possible to do in Win10? Or not? Les1 have more cutie faces i guess.
If it’s just for faces, don’t change your FW. Add them directly or put my launcher.
