Hi guys,
Are you aware of any update to I4 firmware update? There are a couple of issues I have found using my watch that are quite uncomfortable:
- I don’t use a SIM card. I connect to my iPhone via Bluetooth. Once I connect it, if I run away from my phone, once I return my watch won’t reconnect automatically. I need to repeat all the process or reconnecting it manually again.
- Everytime I connect my watch to the phone via Bluetooth, the TIMEZONE gets reset to GMT + 0:00 and therefore the time of the watch changes. I live in GMT -3:00. Again, this is anoying because as I mentioned previously I need to reconnect it manually several times a day and every time I need to set back the TIMEZONE.
- Finally, the backgroud image used for notifications is too colorful. I have tried downloading some phone applications to change POPUP NOTIFICATIONS but none of them worked the way I expected. It would be nice to be able to select a background image for notifications.
Does anyone else have these same issues?
Many thanks,
Sergio
