Is there possibility to upgrade 600mAh battery in kospet hope like 900mAh or 1200mAh. Clock functionalities all good except the battery. If we increase the battery power its very useful.
No sorry . There is not . What have you tried so far to preserve battery power ?
I dont tried externally. But within clock, using less number of applications running in background. I see hospet power version they introduced 900mAh, why can’t we introduce that in this version. basically board requires same voltage capacity may be regulatory chip may corrupt??
To be honest . The manufacturers go forwards and not backwords so they generally dont take a old watch and upgrade it with bigger batterys . And as we are now seeing A10 it wont happen . Good use of wifi and Gps always helps when not needed .
just take a look at aliexpress and see if you can find a battery that has the right connector and will fit inside the watch
