Is there an application that allows to STOP charging at 80% for Android 8.1.0 smartwatch? I mean for devices with small square displays of ~139 mm.
It should allow to stop battery charging at 80% to increase battery life.
Thanks!
Thanks!
Moved to unsupported watches
search on youtube you’ll find a ton, or some old website hmmm HappyMod maybe
ACCA magisk module
Thanks. I think that you meant acc-magisk-module at GitHub - Ian7672/acc-magisk-module: Advanced Charging Controller · GitHub but it seems that it requires rooting the device. Is there any application to do it, but not requiring rooting? Thanks again.
not possible or buy a charger with app support so you can have a set timer to turn off when it reach ~805
AccuBattery app, has feature where it goes brrrrrrrrrrrrrrrr if you set a charging limit
