Is there a way to shrink an app display to reach those settings and menus cut out from the rounded form factor? Thank you.
On my watch it is possible.
Which watch is it? They nearly all have this capability now.
An alternative is to root the watch (using our proper root tools) install xposed framework and use the xposed module which does this per app…
Thank you. I have a domino dm368, which I guess is a Lemfo l16 rebranded. What should I do? I tried double tap and other tap and gestures, no joy as yet. Thank you.
Long press the button and there’s an option to use square view for third party apps
Found it! Thank you very much!
