I need help to root on my Lem5.
I’ve tried it with Kingroot but I can not give permissions to a purify app because of the accessibility of the round screen.
Is there any method to do it?
If you can lend me a hand I will be very grateful.
regards
Necesito ayuda para realizar root en mi Lem5.
Lo he intentado con Kingroot pero no puedo dar permisos a una app purify por culpa de la accesibilidad de la pantalla redonda.
Existe algún método para realizarlo?
Si me podéis echar una mano estaré muy agradecido.
Saludos
Apr 8, 2017 14:47:36 GMT 1 epicuros said: I need help to root on my Lem5.
regards
Saludos
The way I did it was flashing TWRP recovery with SP tools, then transferring SuperSu to the watch and flash it with TWRP.
TWRP is very difficult to use as it is upside down and at an angle, but it does work.
seb84
July 2, 2017, 4:05am
#3
there is a new twrp that can be used
yadi.sk/d/G4SXEIU83FaKXk
download this folder and use sp tool to write them:
drive.google.com/file/d/0B3xyOuab2f-OQWE3WU0yUTc4YkU/view
after flashing boot into twrp recovery and install super su:
s3-us-west-2.amazonaws.com/supersu/download/zip/SuperSU-v2.82-201705271822.zip
i used the modified mtk tool for win 10 64bit and setting usb debugging after normal reboot, to boot into twrp recovery
first boot will take very long, just wait and have no fear, it isn’t stuck
this twrp is in the right direction
after flashing super su i would hardly recomment to setup xposed and greenify
any more questions let me know
regards
Saludos
The TWRP available on this forum,
here , is not upside down. Have you tried it?
seb84
July 4, 2017, 9:43am
#5
No didn’t try that one, while i saw the one i used now, is version 3.0.3 so newer also i needed the files for the w618 and i saw the links i posted had everything
