KW88 is on android 5.1
KW88 pro is on android 7.1
Is it possible to flash the KW88 with the KW88 pro ROM?
Regards
Regards
I don’t think so, hw is not the same !
If possible if you find a firmware with the same ram layering and internal storage. I have a Kw88 that I installed the rom but the screen was inverted and thanks to the forum I could solve it.
possible!!!
Thanks for the reply. Do you have a link to update the OS?
Regards.
It is not possible to flash the Android 7 kw88 pro firmware on to the Android 5.1 kw88.
If you try this you will will not be able to use the watch at all.
FeraLab_FW-v6-20190301-Android 7 for KW88/KW88Pro/KW98/KW99 4pda.ru/forum/index.php?showtopic=768858&view=findpost&p=82897640
