Is it normal that my no. 1 d5 gets battery low too fast, from just about 6hrs on idle mode? From time to time, i just check time. Also i notice that y steps no. Increases even if i didn’t turn on pedometer. Do i need to return it? Just a day and half from the time i receive the watch.
Here’s the checklist of things I’ve found useful to maximize battery as a standalone watch:
- Minimize screen brightness
- Minimize having GPS, Bluetooth or Wifi turned on
- Install the app CPU Spy Reborn, run it and verify that you see a large percentage of Deep Sleep.
- Restart
- Ensure you haven’t installed any apps recently that could be running in the background.
- Format and flash
–> After this step, I root the device and make a TWRP backup (skip backing up Data) once I get it the way I want. Then, if it starts behaving weirdly, I can restore the backup.
how do you get into TWRP on the No 1 D5
Lokifish created an SPTools post for easy rooting…and it includes TWRP.
https://plus.google.com/u/0/+LokifishMarz/posts/WVhaf9ztpzf
How about pedometer? Can i deactivate it?
I don’t believe the pedometer can be disabled…at least I’m not aware if it can.
Pedometer can be disabled if you are rooted and use twrp
