IQI I4 Air firmware
Hi there,
someone can explain me which is the difference  in the two firmware for I4 Air?
How can i do to understand which version I must use to upgrade my I4 Air?
  1. AQR-LAUNCH-I4Air-1602-CAMERA-Fitness-HEHUI-NHT-V01-20171121
  2. AQR-LAUNCH-I4Air-1602-CAMERA-Fitness-NHT-V1.0-20171122
Davide
IT should be written somewhere in your settings/About window.
Ok, I see in about menu AQR-LOUNCH-I4AIR-1602-CAMERA-FITNESS-NHT-V04-20171127, so I’ll flash the new firmware AQR-LAUNCH-I4Air-1602-CAMERA-Fitness-NHT-V1.0-20171122.
It’s possible to save or to download the stock firmware?
Davide
Mar 16, 2018 17:11:12 GMT 1 nyxx said:
Ok, I see in about menu AQR-LOUNCH-I4AIR-1602-CAMERA-FITNESS-NHT-V04-20171127, so I'll flash the new firmware AQR-LAUNCH-I4Air-1602-CAMERA-Fitness-NHT-V1.0-20171122. It's possible to save or to download the stock firmware?
Davide
You’re flashing an older FW ?
Davide
I think not. No stabile conection with pc…, so no backup. You can try with twrp but if you lost twrb recovery is useless… Problem is that if something goes wrong with in updating process ( break usb conection conection, wrong firmware…) your watch is lost forever.
I want to flash the new firmware with the bluetooth call ( AQR-LAUNCH-I4Air-1602-CAMERA-Fitness-NHT-V1.0-20171122 ), usually I prepare a backup plane if something going wrong during flashing the new firmware, for this I ask you if it’s possible to have or to extract the original firmware, in my watch now there’s the AQR-LOUNCH-I4AIR-1602-CAMERA-FITNESS-NHT-V04-20171127 ( stock firmware ).
If it’s an impossible thing, I proceed to flash the new one firmware.
Mar 16, 2018 16:03:48 GMT 1 nyxx said:
Hi there, someone can explain me which is the difference  in the two firmware for I4 Air? How can i do to understand which version I must use to upgrade my I4 Air?
Davide
Flash the second one because 1st one won’t work it shows blank screen only .
