Does someone have i3 firmware. Updated via OTA = dead battery on 94%
Installed from kw88 - screen upside down
So looking for i3 firmware. Looked all forum and can’t find it.
Can someone help?
Jan 17, 2017 21:55:18 GMT 1 sky03611 said:
Does someone have i3 firmware. Updated via OTA = dead battery on 94% Installed from kw88 - screen upside down So looking for i3 firmware. Looked all forum and can't find it. Can someone help?
did you install kw88 firmware on your watch? if not, just reset the watch and see if it helps if not notify here.
Installed kw88 firmware =(
Ok found link on mega installed and everything ok.
If someone else need this here s a link
mega.nz/#F!clIRkSpZ!X_kDwHqXDnGy11WSK1wI2w!FxJRUTrB
Jan 17, 2017 23:14:45 GMT 1 sky03611 said:
Ok found link on mega installed and everything ok. If someone else need this here s a link mega.nz/#F!clIRkSpZ!X_kDwHqXDnGy11WSK1wI2w!FxJRUTrB
thanks for sharing i did'nt see that the file includes the i3 firmware the title is misleading:) (fixed)
thanks for sharing i did’nt see that the file includes the i3 firmware the title is misleading:) (fixed)
Thanks Sonia - it was a little confusing
