Oh now I’m starting to understand everything.
I suggest you if you can on a PC to use the forum.
It shows a lot more information there than on a smartphone.
That way, you won’t get lost among the information years ago, probably even made for android 5.
You can also see the dates of the posts.
Using Goggle Translator is also easier.
You can check back the translation if you try to translate the English translation back into your own language (believe me you will be surprised) before publishing.
Believe me, you won’t miss anything, but your popularity is hard to build that way.
If you are near a PC, you read, search, answer.
