Installing apps from GP S1/Q7 PLUS - scrolling problem
Hi
I have problem when I want to install some app for example Messenger Lite from Google Play Store. When I click install button the pop-up shows up with permissions and I can’t scroll it down to press install again:-/ I’ve tried squere mode and nothing changed. Does someone have solution for this issue?
Maybe try with vysor app on your PC
Nov 15, 2018 21:46:48 GMT 1 ktl20 said:
Hi I have problem when I want to install some app for example Messenger Lite from Google Play Store. When I click install button the pop-up shows up with permissions and I can't scroll it down to press install again:-/ I've tried squere mode and nothing changed. Does someone have solution for this issue?
do as ricktop suggested or use mobizen for pc they will give you this option, one of the reason i've stopped using Finow watches just because of that till now they have'nt much modified all apps to suit these watches as other manufacturers.
I don’t know what happened but I can’t use mobizen becouse I can’t use app on my watch can’t use options can’t click anything
when i want to use programs like vysor apower mirroring etc my smartwatch restarting when connecting and i cant use programs like that…any ideas?
Nov 16, 2018 16:52:27 GMT 1 ktl20 said:
when i want to use programs like vysor apower mirroring etc my smartwatch restarting when connecting and i cant use programs like that...any ideas?
your watch and same program on the pc are with the same account?
Yes everything is fine and when it start connecting (USB debugging on) it restarts I’ve tried lot of different apps
Nov 16, 2018 19:51:52 GMT 1 ktl20 said:
Yes everything is fine and when it start connecting (USB debugging on) it restarts I've tried lot of different apps
the only other way is use magnification to try and reach these areas.
I have enough :confused: i cant use this kind of apps like apower mirror … when my phone or pc is at the same wifi network ma smarttwatch finds my other device but when i try to connect them (smartwatch to phone or pc) my watch restarts:/ i cant even use magnification becouse i cant press it:/ the button for it is not visible…why my watch always restarts when i try to use this kind of soft?
help me with that please
EDIT:
I made Air Mirror working. Mirroring watch screen to my Honor 8x .
Controlling the watch screen over the phone does not give me the opportunity to access hidden things:/ or i dont know how to do it…maybe some advice?
ktl20
sorry, but the only way i know is using mobizen, it seems that finow has’nt worked much on imporving their software and that is a shame:/ let me charge and turn on one of the s1 and see if i can get a solution for you
Nov 19, 2018 13:58:41 GMT 1 soniasophie9697 said:ktl20
Ok so  i am waiting:)
