@boris_lamy it depends on your service provider - check if they use 2000/2100 for wcdma and if they do you will be fine.
@C_For did you purchase your watch through Aliexpress? If so it is not right to expect the ODM to replace the watch. I don’t agree with asking these kind of quetions in a public forum and Zoe has been asked not to answer them. We act as a “go between” for the Vendors for a reason. This is one of them.
If you did buy from them direct you would be better off emailing them privately
@Pablo_Eleven_Pablo11 all french providers give 900-2100 3g . My kw88 is OK with Bouygues Télécom. Was an information, not à question
@Pablo_Eleven_Pablo11 I will speak with my seller but the information provided to them was from King Wear so I have bought a model technically falsely advertised to support a band that it now turns out doesn’t.
Anyway, as I said, I’ll manage. I can’t see me sending it back.
Yeah - we’re all in the same boat
Will the kw88 work on the T-mobile network? If not, which network will it work on in the states?
Hi! Thinking of getting a KW88,
but only if the straps can be swapped out tho’. Can it be done?
@Jim_Docherty not without losing all the connectivity like WiFi, 3G and GPS
