I4 air battery drain
Hi everyone,
I wear my watch while sleeping to check time occasionally.
Morning I found that the battery drains nearly 30% over a span of 9 hours without any use.
There are only 4 apps installed. None of them were running in the background.
I haven’t inserted SIM card. All features were turned off.
I checked the battery usage and it was “watch idle” that consumed battery.
How can I solve this?
Mar 23, 2018 4:35:34 GMT 1 akdevil65 said:
Hi everyone,
if you do’nt have a sim in put the watch in flight mode and you can still use the watch with gps and wifi and bt and see how the watch behave, btw, i highly recommend to let the watch reach 0% and charge it to 100% that helps with batttery issues.
capt jon
Thanks for the information. I’ll try that and let you know
