I think there should be an order for app
Good morning to all of you, I received recently my LEM7 after a short experience on LES1.
I have a Z28-LEM7-NHH-V1.0 firmware that I did not touch (should I upgrade?)
My need is only to be connected to my main smartphone, but also when watch and phone are not close, so I needed a sim and an app that is called Join ( already used on LES1)
It tootk me a good week for setting all up and the only way I found to solve, was to follow a specific order in installing apps and fetures. Otherwise watch blocked and nothing works.
So the order I followed was:
  • factory reset to bring the watch at its original conditions
  • install the sim and verify the right communication ( I have an iliad sim)
  • install Join app and check the connection and the transmission of the notification
  • install Ricktop launcher at the end and give all permissions.
If I am following a different order in installation, nothing works.
Now all is smooth and battery is used from 6am to 10pm with 10-15% left.
Any of you was experiencing that we have to follow a priority list for apps and services?
Jonh
