I think my watch Finow X5 is dead. Nothing I do seems to get any response. stop in smartwatch init screen
I brick my x5 and W10 cant detect the watch. I install W10 MTK drivers
Now appear in Flash Tool
brom error s_com_port_open_fail (1013)
Sounds like your drivers are not working properly or the charger is not making a good contact or you need to try a different usb port.
An now
brom error s_ft_da_no_response (4001)
https://forum.hovatek.com/thread-439.html
Error 4001
Message: S_FT_DA_NO_RESPONSE or
Meaning: SP flash tool is having difficulty communicating with the device
Solution:
- Change the USB-port
- Run SP flash tool as Admin
- Ensure to install the correct drivers (see https://forum.hovatek.com/thread-440.html )
- Try another PC and USB cord
- Ensure the phone is switched off with a charged battery inside when connecting to the PC for flashing
Thanks!
the problem was the cable
Now the problem is I cant get into google play
Oh - well at least your watch isn’t broken
What happens when you try to sign in?
Do you have a good connection to internet?
Thanks friend!
Yes, is good
Error recuperation server information RH-01
Clean data from Google play services and Google play, should come back
@john_gully yep should work but depends if he can access the app manager menu.
To be honest he would be better off going into the watch settings and doing a factory reset.
I tried with sim card and it all sorted
THANK YOU VERY MUCH
