I received yesterday my domino dm368. Is pressing the side button the only way to activate the display? Thank you.
PS any other “start here” suggestion would be very welcome, thanks
Go over to the technical forum for all the FAQs and documentation.
Tilting the screen will wake the watch if you have the option ticked in power savings…
I cannot find the power saving section you mean. I went into settings there is something but if I click theres only a graph showing battery usage… Where should I go instead? Went into the forum didn’t find anything for dm368… My mistake?
Look in settings, display…
Thank you, but it’s not there. There’s a display section but without that toggle.
Could you find any auto-wake-up setting? Turn over your wrist and the screen would be on display(just as Pablo said). But since you can’t find any on settings…
I found something. Settings, Gestures, bright display taishou. If flagged, the watch shows a reduced subset of information when the arm is turned up. Go figure… Thanks again.
