I need help with flashing the Lem5 firmware onto the watch.
I need help with flashing the Lem5 firmware onto the watch. I ended up bricking the watch after deleting a downloaded watchface that was active. The watch would not boot past the startup logo. I was sent the firmware and sp flash tool from Lemfo support and then I downloaded the MTK drivers. After I flashed the firmware, yellow progress bar said 100% complete and the green checkmark box popped up. When I took the watch off the charger, the watch wouldn’t even boot at all. Just stayed black but before at least it would boot to the logo and show the battery life bar when charging. Now nothing. Tried flashing again and the watch endlessly loops from connected to disconnected. How can I fix it so I can get the firmware to work properly on it? Thanks.
You really need to ask in the right place. In the very first post here it explains that this is for graphic design mostly.
You need to go here
http://roundandroidwatches.proboards.com/
