I made a Pip-Boy skin for y’all (it’s my first one, so be gentle with me :3) Also, it doesn’t work properly on my D5+ (everything is gone except the time and the background image
https://mega.nz/#!5hM0AT7Z!tt6Kl5eORxeOL2u6MM4akgsSepw7423mkptPr-e9Rfg
If anyone tested it on his watch, please give me some feedback so I can improve it, thanks :3
@Sebastien_QUEROL Hi… if you send me your email address I’ll send you the download link… you can use ClockSkinMaker to see how I made it work… it might help you to fix yours…
https://plus.google.com/+AndrewDavis-the-omnipotent/posts/iYofXGNkYyr
Thanks How do I send you my e-mail ?
@Sebastien_QUEROL you could type it here… and (if you want) then remove it after I’ve sent you the download link…
I have a D5 so I’d like to hear about how it looks on a D5+…
It works really well
Is it blue and green?
No, that’s the white balance that screwed up
Do you use ClockSkinMaker (CSM)?
Yes ^^ I’m easilly lost in all those .xml’s :3
Me too… I looked at you watchskin and couldn’t see much wrong… but I have had problems if the steps character set isn’t correct… you (normally) have to have 11 numbers - 0,1,2,3,4,5,6,7,8,9,0… ???
I use Gimp for the image creation… I find that getting the character sets (numbers, days months etc) to be the correct size is also important… some of yours look like they could be neater
only ten numbers are necessary if I remember well
And yes, I did that in a very hacky way but it was mostly for experimentation to master CSM
Compare yours and mine and see if there are any differences… and make little adjustments to see if it helps… good luck
Thanks a bunch !
