I bought a KW88 from DealExtreme (EU warehouse) and they sent me a chinese firmware version with baidu (instead of Google Play) and many other bloatware.
I want to have Google Play. What do you suggest me to do?
Find and flash with othe firmware? Keep the firmaware and install Play (already tried, Play wont run)
HELP PLS!!..
(KW88_CS1_A_GSM_PHT_20161108)
Really? The stock image supports EN and CN and when in english it seems to work normally except I dont have Google Play (and when try to install through apk it installs but wont run), and have some extra chinese programs I surelly dont need…)
SOLVED - Just flash it with other firmware. It worked for me!
What did you do? have you a link or instructions as mine is the same cannot install apps and have the Baidu and other stuff… Thanks
