hii ,i want to root my kw88 pro and i dont have computer ,can i do it on my watch itself,i know a apps like kingroit but do they work on smartwatches??
U can’t. Simply.
do'nt try them you'll end up needed to flash the watch, why do you need root?
i want to increase battery backup of my watch ,so rooting watch might open possibility for that???
check the twrp section and i know there is one for your watch all you need is to flash it with the right twrp and from there easy to root.
that is the problem miss sophie ,i dont have computer to do that anyways thanks for the guidence
Does rooting increases the battery life? i am also having KW88Pro and seriously need some extra juice out of the battery.
can, with wakelock or similar apps you can see what is draining your battery and just disable it.
hey sathyak if u want to increase battery life 9n kw88 pro do one thing disable play store ,and play store services on ur watch it will increase ur battery life to 8 to 10 hours ,use play store when u really need it
Nov 11, 2018 6:11:19 GMT 1 shiveshwar said:Nov 9, 2018 4:53:21 GMT 1 sathyak said:
Ok thanq, will do and check
