Please post in english here. Thankyou.
Hello, could someone share the âboot.imgâ of the Optimus pro patched? is that I am having problems with Magisk and I need to root.
Thank you
Have you tried flashing Magisk from TWRP?
Well, I understand that if I install (flash) a patched âboot.imgâ, the smartwatch will be root. No need for âTWRPâ. it is right?
Yes, but if youâre having issues, itâs easier to flash TWRP then MagiskâŚ
What I was referring to, is to be able to âflashâ a âboot.imgâ patched and shared by another user along with the other files of the âROMâ as another user posted, in order to have the phone ârootedâ . Is this possible?
So if someone shares a TWRPâd recovery image and a rooted boot.img, Like they did with the âRooting Kospet Hopeâ, everyone that comes along later and reads this will not have to jump through hoops with Magisk and TWRPing the watch? Then just go figure out how to flash the two files (which I saw a pretty good write-up around here somewhere) with SP Flash Tool. Did I sum that up pretty well?
Just download the kospet rom and make it flash using flash tool ⌠Make sure only to select
- System
2 . Userdata
3 . Cache
Rest unselect
Boot,recovery , nothing to flash just above things
Hi.how can root smartwatch kospet optimus pro?
Havenât you read the above posts ?
Hi brother, i have patched it,nrenamed to boot.img to flash wih spflash, and spflash showed the big green tick⌠But the status of magisk root is
Latest: 20.4
Installed: N/A
Ramdisk: Yes
A/B: No
SAR: No
Crypto: N/A
How to get the status to be installed?
did you patch it on the watch or on a phone?
