I wonder if we have a tweak to allow the display to remain longer on after (tilt to wakeup).
There is a " always on display " option if you use universal launcher . Be carefull using this function depending on what type of screen your watch has . It has other options you may like
Thanks for the suggestion. I use the Kospet Prime and I read that using always-on display is a bad option for this type of screens as it consumes a lot of battery and may cause display permanent burn-ins. Thats why I asked about an option or tweak to make the display remain longer after tilt.
You are correct although we have not seen any screen damage at all so its at your own risk . I have used ā aod ā with no issues . I have tested watch with everything on , on my prime
Aod
Wifi
Gps
3g
Bluetooth
I got 8 hours
Oh wow that is impressive!
I think Iām gonna give it a try then
Always On Display
RK
Yes . Always on display
Thank you @Dr_Andy_Vishnu and @irohunk , well I thought it was some new app. I also searched on app. Store
