debugging should’nt be on when you want to see your watch on the computer. the moment you connect the watc mtp option should appear if not (after installing usb mtp and drivers) that means you have a problem with the cable.
I contacted Microwear, got a lot of stuff about should use W7. They sent me SP drivers but to no avail. I just received my Kw88/99 cable, tried it, worked immediately and the magnets are much better too. I have asked them for a free replacement???
Aug 31, 2018 16:28:22 GMT 1mrmike said: I contacted Microwear, got a lot of stuff about should use W7. They sent me SP drivers but to no avail. I just received my Kw88/99 cable, tried it, worked immediately and the magnets are much better too. I have asked them for a free replacement???
yeah...the cables are not that great some works and some not, for charging they all work but not always for data so it is better to buy from a seller that promise you that the cable is also for data.
This is the message that I have just sent to Microwear. “OK, the reason your cable does not work is that it is wired incorrectly, the 2 centre pins are crossed over. These cables can never work for data transfer, they can only charge the battery!!!
Maybe better quality control might be an Idea!!”
