I am not sure if anyone is interested. Most of the face engines on Android 7 and higher can also display the second hand with “digital movement”. That is, the second hand jumps forward in steps of one second. All you have to do is open the clockskin xml, then add a line:
Of course. I did this in the testface. All you need is a 2nd layer for the shaddow. The center of the shaddow layer is then shifted by 4px on the x axis and on the y axis.
Annoyingly, there are some new functions that are not integrated in the WatchFaceDesinger. So like this one. the only way to use it is to add it manually.
Nice tip, thank you very much. I am working with WFD in the last beta version and have to make changes in the xml file anyway, f. e. battery hands. I will test it in the next work.
I have tested this function on my Genesis and it works ok. But there are limitations:
if you make the change for one second hand, then it applies to all other second hands as well. It is not possible ( or I do not know how ) to have a digital second hand and another smooth one (with a different Auto Rotation Multiplier f.e. ).
If you make this change in the xml file, it is not possible to use a picture with Auto Rotaton Balance Wheel in the right way. There is no smooth balancing any more, You can only see the left and right deflection every second.
