For those who like making animated watch faces lots of things are possible with WFD . Slide shows , flashing lights and moving objects . I have attached the .xml file and images so you can see what is possible . The possibilites are endless . This can be used as a starting point for beginners
Yes, most excellent, and it will work with stock launcher!
Thankyou . Its soooo easy to cheat with .gif files lol . Like i often do
Downloaded both, but in CSM’s toolbox there is no option that uses Blink; therefore, I can’t activate the images…
Open in WFD , and look through .xml file. Thanks
Tim - Opened Blink.xml in WFD, saved to Clockskin, found Blink.xml there, but there is no tool in the CSM toolbox which will activate it…
I’ll be honest i have never used CSM as WD does all that i need and more . Thanks
