hola alguien me explica como hago para instalar las esferas en mi kw88
English please. This is an English community.
La verdad ni idea, ya que no poseo ese modelo xD. Pero hay una opcion y es un launcher, esta en la publicacionla la pagina si quieres usar las caras de D5. Lo uso en mi LEM3 funciona al 85%.
Hi Gustavo.
First you must download and unzip the file. Then copy the apk files inside the zip to the watch.
On your watch you have a filemanager.
Use the filemanager and go to the apk files that you have copy.
Tap on the apk file.
A mask will ask you for installing.Tap on YES.
The watchface will now installed.
English or your questions will be ignored. It’s not that hard…
@Pablo_Eleven_Pablo11 sorry I don’t know it. Excuse me please, regards
@ENRIQUE_BM
thanks, no problem
Hi, I would like to know if the kw88 spheres are compatible for lemfo5, thanks.
