Hi there as promissed here the first chronoswiss replica interpretation. Works on stocklauncher xseries.
Hi there as promissed here the first chronoswiss replica interpretation. Works on stocklauncher xseries. Made some minor changes to the face. Shows power, day and heartrate.Left one is my work right original.
As usual have fun and enjoy!
Credits:http://www.chronoswiss.com/startseite.html#chronoswiss
Download:https://drive.google.com/file/d/14zNQmT1CQhM5eq4k6-gb0tTaqHWa9jfS/view?usp=sharing
@Victor_Often ty
@Jurgen_Oberst everything is laconic and beautiful.
Wow Jürgen!
Exellent of course, but…why on my Finow X5 Air HR digits are out of the window- landed somewhere on the left dial?
@j_wo_jak hmm weird did you tried the other version i posted in the kw88 section? Pozdr.
Yes, I did. Also works wrong but don’t worry- maybe it’s some bug inside the X5 Air stock launcher?
@j_wo_jak if you use universal launcher it might be the problem or solve the problem. On my h2 it works as it should be and no other reports of this issue so far. so i have no idea if its your watchengine or something else. Maybe u can correct yourself in WFD. Greets
I will and the HR is not very important, actually. I don’t use Universal Launcher, for now I prefer the stock one: hundreds of clickskins works on X5 Air ok, there was a problem with two or three…
@j_wo_jak post a photo whete hr is located and i can fix it for you. Greets
Thanks in advance
@j_wo_jak kk nara
@j_wo_jak what version did you download the for x series?
yes
@j_wo_jak 10 min you will get it first a smoke.
The other version- almost the same problemmissing/deleted image from Google+
Thanks, but still with error- exactly as we see on “clockskin model png”
@j_wo_jak https://drive.google.com/file/d/1tbQFjpKqQDep_XXoR817Sj94QtPEU2UT/view?usp=sharing
@j_wo_jak if this doesnt fix the problem i have no idea whats going on with the skin or your watch. Greets
Great! Works fine now- thank You very much for your work!
