Updates:
I decided to wipe the data and restart my watch-it hasn’t made any difference.
THEN i made some changes, and now my battery lasts for 3 DAYS (!)
Although the Android system takes more than 90% of the power. This is what i did:
- Installed Doze from the play store.
- In developer options i limited the number of active processes to 4.
- Uninstalled the assistive touch (with a little sorrow), and installed the floating toucher ex instead.
The watch is working flawlessly, and i recommend you all to try these.
Thanks @Matan_Milles . I reposted your comment in the show notes for this video: https://www.youtube.com/watch?v=yqDUKkr8WKk
@Matan_Milles Hopefully famous and appreciated! These are good suggestions most of us wouldn’t easily figure out.
I flashed the new firmware (160524) but unfortunately didn’t work for me. The battery was depleted really fast so I went back to the 160414 firmware version. I will try setting the plane mode with bluetooth on and will avoid the screen shaker app.
@Jeronimo_Del_Noval get Doze! It’s a miracle!
I had this issue and after installing cpu monitor I realized it was never going into deep sleep mode. Had the watch for 4-5 days and then updated to 5/24 and thru several reboots it still didn’t sleep right. Rooted and ran an init.d script or two and now she sleeps like a baby!
@Edward_Henry well if you open it… which scripts?
