Hi everyone.
Here is another WARNING about firmware. Mainly for Domino 368, Lemfo LF16, Y3 and IQI I3 users.
I posted about this before but here’s another one
These watches have been built with 2 different screens.
One version has hehui in the build version in Settings/ About watch/ Build Number.
The other does not.
The hehui screen is newer and uses different drivers so you need to check your firmware version before flashing.
If you get it wrong you end up with a black screen and nothing else.
BUT - DON’T PANIC - all you need to do is flash the correct one afterwards and your watch will be OK.
So just be sure to check before you flash
Moderator team.
