Hi collegues how would i manage that: i need power displayed by a hand on 1/4 radius . Multiplier? Other tricks. Thanks in advance! Greets
90 degrees? Mulrotate -2
@Jacek_Klodzinski needed that for the griffin power i did one position for each digit on battery layer it solved the problem. yep 90 degree -2 multirotate doesnt do the trick on my wfd. need to test it once again with -2.Greets
@Jacek_Klodzinski tried rotate multiplayer -2 and stil it does 180 from 12-6 i need 9-12 only. Greets
I use it very often. Try to check in my watch faces with 90 degrees power movement. I can’t check it now because I am already in my bed
Did you check in the watch? Or only in WFD? You can also read my discision with Marco on the forum in posts atvthe end of WFD topic.
@Jacek_Klodzinski hmmm good point didnt try on watch itself only wfd i thought if wfd shows it that way then our watches too. I will check one of yours to learn. Thank you!
@Jacek_Klodzinski Dzieki dobranoc!
Dzięki. Wzajemnie.
Hi @Jurgen_Oberst , I am planning to buy z10 smartwatch. Can I use this clockskin to z10? Will it be compatibe? Thanks
