Help with KW88 please ..
someone else wrote in the forum that it took atleast 20min to come out of coma …
hmm… 25 mins and its still in coma …giddiyup …
Good news is that you finally succeded in flashing it.
Bad news is that you probably took the wrong FW, so try again with the FW from here. It’s really not normal that only a part is flashed and not all…
nope. still returns to the same place again. so still no gud news…i tried flashing with another machine. same thing. just doesn’t flash. i tried removing the batt, but
i couldn’t remove couple of screws from behind. the head of the screws just eroded, and now i am unable to turn the screws …
for the moment i have given up. may the watch RIP ! bad luck.
One thing i remember that i did. i used a quick charger to charge the watch when it had crashed… don’t know if it is advisable to use a quickcharger 2.0 to charge the watch.
it crashed during that time, and also it was during that time that i had installed the watch droid app.
giving it one last try after batt drained. flashed it again with the june edition. now it is charging. i’ll switch it on later and see if anything has changed …
nope. even a flash after batt dead also didn’t work. still shows exact same thing. don’t know how it is so stubborn …
Am doing a memory test using the sp tool…
============ Memory Detection Report ===========
Internal RAM:
External RAM:
Type = DRAM
Size = 0x20000000 (512MB/4096Mb)
NAND Flash:
ERROR: NAND Flash was not detected!
EMMC:
 EMMC_PART_BOOT1 	Size = 0x0000000000400000(4MB)
 EMMC_PART_BOOT2 	Size = 0x0000000000400000(4MB)
 EMMC_PART_RPMB 	Size = 0x0000000000080000(0MB)
 EMMC_PART_GP1 	Size = 0x0000000000000000(0MB)
 EMMC_PART_GP2 	Size = 0x0000000000000000(0MB)
 EMMC_PART_GP3 	Size = 0x0000000000000000(0MB)
 EMMC_PART_GP4 	Size = 0x0000000000000000(0MB)
 EMMC_PART_USER 	Size = 0x00000000e9000000(3728MB)
UFS:
ERROR: UFS was not detected!
============ RAM Test ============
Data Bus Test:
[D0]
[D1]
[D2]
[D3]
[D4]
[D5]
[D6]
[D7]
[D8]
[D9]
[D10]
[D11]
[D12]
[D13]
[D14]
[D15]
[D16]
[D17]
[D18]
[D19]
[D20]
[D21]
[D22]
[D23]
[D24]
[D25]
[D26]
[D27]
[D28]
[D29]
[D30]
[D31]
OK!!
Address Bus Test:
[A1]
[A2]
[A3]
[A4]
[A5]
[A6]
[A7]
[A8]
[A9]
[A10]
[A11]
[A12]
[A13]
[A14]
[A15]
[A16]
[A17]
[A18]
[A19]
[A20]
[A21]
[A22]
[A23]
[A24]
[A25]
[A26]
[A27]
[A28]
OK!!
RAM Pattern Test :
Writing …
0x44332211,
0xA5A5A5A5,
0xA5A5A500,
0xA500A500,
0xA5000000,
0x00000000,
0xFFFF0000,
0xFFFFFFFF,
OK!!
Increment/Decrement Test:
Writing…
OK!!
anyone ? what does nand flash not detected mean ? hmmm…intriguing …
