Help!!! No1. D5 watch doesn't turn on.
Help!!! No1. D5 watch doesn’t turn on. It doesn’t give any indication to be charging.
If I connect it to the computer it does a USB connected sound, then after a few seconds a USB disconnect sound - and it keep doing those connected/disconnected sounds over and over. So maybe there is still life in it?
You can try :
Another USB port
Another USB cable
Find a position for the watch where the connection is stable
This happens to me also…
Tried it. Also tried different computer. And tried connecting the charger the the phone charger :frowning:
This will lead you to a 69 comment thread :slight_smile:
https://drive.google.com/file/d/0B9c-vl8oxm2EeU5lUXgzQkp1TEk/view?usp=sharing
most likely a faulty charging dock, check the pins, maybe one or more pins are not in contact with the watch.
Disconnect the battery it’s the only way to get it back
@Ophir_Oren this is a question for the technical forums here: Round Android Smartwatches
http://roundandroidwatches.proboards.com
This community is for general chat and faces
