Help ! I downloaded a .zip pack of watch faces and when I extract them and try to use the IMPORT feature on watchmaker, it does not find a file to import even though the folder has files in it. I believe it’s looking for a .watch file to import and the only .watch file is in ,xml …this happens for all zips where watchmaker can’t find a file to import…what am I doing wrong…thank you
You need to rename .zip to .watch, if it contains right format.
For which clock do you want to do this ? From where did you get the .zip package ? ( f.e. If it is for a D5 and the package is for those watches, you only have to unzip the package and copy the folders to the clockskin folder of WM. When starting WM you can see the clockfaces to be clicked on the left side. Thats all. )
