I can’t access to my watch anymore, do you know how to hard reset the LEM12 to restore the factory settings?
You can flash the FW instead.
I saw in the hold models you just needed to switch it off and hold the back button to start the factory reset, but it doesn’t work on this model. How can I flash the firmware? Where I can find the sorftware and the firmware?
In the official website I found the software, but there isn’t any firmware for the LEM12
Try using our search function
There is no search function, if I’m in the right website, but with this brand I doubt. Anyway thank you very much, I’ve installed the one you sent me and it works fine now!!!
can someone help my, i forget the pattern lock. now i cant get in to menu. only last watch face
i’m just user not familiar to rooting etc
thanks
Hi . The only way you can fix this is by flashing the firmware .
Read this
https://drive.google.com/file/d/1xa7e_4byI8UrTvZ62eMj_C_YVtalB57_/view?usp=drivesdk
thanks a lot
i will learn first
Use this newer version of LEM 12 FW - 1.3
It has google issues fixed.
where i can find mtk driver for windows?
I was sure the drivers are in the tutorial file ? I could be wrong . Its been a while
@gayeel They are attached to various topics but here is a link:
in my experience, flashing works perfectly without the drivers as well, at least on windows 10
you right, in the flash file already have driver installer
thanks a lot, now i can use my watch again
regards
from Indonesia
I’m glad to know its still there
. Good to hear we got you going again
Hi moderator! I’d like to ask how does flashing work? I have rogbid king watch. I can’t access to it anymore… Pattern lock doesn’t recognize my password anymore… When i contacted the support rogbid they told me to disbale the face recognition ( THE ONLY WAY I CAN ABLE TO ACCESS IT ) BUT NOW I don’t have any access anymore because i deleted the face recognition… please help me…
We do not support this watch. I suspect that this is why we can also provide the required firmware.
But maybe I’m wrong and @pablo11 can help.
We can’t help with this.
The only way is to flash the firmware and we don’t support it (as @G1NT0N1C said) so we don’t have the firmware.
What great support they have - telling you to disable the function when you can’t even get into the watch ![]()
