I think the gyoscope is faulty as the podometer and the wakeup function stopped working.
I try to flash the different firmware but it does change anything.
Any idea what to do?
Thanks in advance
D.
So you have flashed with Correct firmware then perforned a full reset afterwards ?
I have flashed lemfo firmware as custom ones… no changes.
And did you perform a full reset after you flashed ?
I ran a sensor test and it says the gyroscope is unsupported. It did list accelerometer and pedometer.
Make sure you went to Settings -> Gesture and enabled both options or they will not work. They may disabled by default.
no I did not full reset, how can I do that? Is it the same as a factory reset?
Yes its the same . Always recommended after flashing
ok thx I’ll give a try
Worked like a charm, thx again for your help
Your welcome . Another satisfied customer
