guys i have a problem with kw88 no active connections drops from 40 % to 0 in 2 minutes
Please check if your watch was actually at 40% (to check note down watch battery % when not charging… Switch off and connect the charger). In my case There was major difference in battery % on watch when ON and whn OFF.
I checked it and it was the 40℅ or so marked
This is quit certain…if both on/off were the same indicator…
Usually when charging over night on one Amp it lasts for two days…and usually full day even more on 3G connection only with minimum activities. I usually walk and even open the speakers on MP3 for more than 45 mins and it consumes about 22 %.
I highly recommend giving it a 1Amp charge over night Turned Off and start measuring the consumption.
Mine does not last more than 7hours even with flight mode on. Do you have pedometer and wrist movement detection on?
pedometer is why I can not turn it off
Pedometer only…
