Feb 3, 2017 6:45:51 GMT 1 sakifx9 said:
I installed the drivers, but the same thing shows up...
go to devices managaer and see if your watch (when connected) is there if not then you'll have to install mtp usb
it says unknown usb device (invalid device descriptor)
I did INSTALL the MTP USB… and the same message comes up…
Feb 4, 2017 5:16:51 GMT 1 sakifx9 said:
I did INSTALL the MTP USB....... and the same message comes up....
Yes I followed every single step, I restarted my Windows 10 machine with the steps provided in this forum to be able to install unsigned drivers, I did everything…
Feb 4, 2017 9:13:10 GMT 1 sakifx9 said:
Yes I followed every single step, I restarted my Windows 10 machine with the steps provided in this forum to be able to install unsigned drivers, I did everything...
just weird, i have the x3+ and just after falshing the rom i had to install mtp usb again but with the s99a i did’nt have to the pc recognize the watch and i also have window 10, but on the laptop it does’nt because i have’nt installed drivers let me see how it goes and see if there is a problem. and i will video the procedure and upload it.
Installing MTP driver for LF16 and ALL watches attached.
Install MTP Driver.docx (166.27 KB)
just weird, i have the x3+ and just after falshing the rom i had to install mtp usb again but with the s99a i did'nt have to the pc recognize the watch and i also have window 10, but on the laptop it does'nt because i have'nt installed drivers let me see how it goes and see if there is a problem. and i will video the procedure and upload it.
I get this error
i.ytimg.com/vi/D0nAPX_DDZs/hqdefault.jpg
Mar 25, 2017 20:52:26 GMT 1 sakifx9 said:Feb 5, 2017 12:28:06 GMT 1 pablo11 said:
I get this error i.ytimg.com/vi/D0nAPX_DDZs/hqdefault.jpg
Oct 15, 2016 14:35:09 GMT 1 soniasophie9697 said:
Sept 24, 2016 18:55:12 GMT 1 rimasi98 said:
how do i connect my Kingwear KW88 to my PC if it doesn’t recognise the smartwatch in Device Manager?
first make sure that you downloaded the vcom drivers and that you installed them.
Feb 2, 2018 12:50:38 GMT 1 harsh said:Oct 15, 2016 14:35:09 GMT 1 soniasophie9697 said:
when i flashed my watch according to your video on youtube after flashing when press and hold power button my watch does not start.my watch is no1 d5.pls help
where is the download link pls?
