rush90
January 13, 2018, 7:19pm
Hi, I have a problem with greenify initial settings. It says to enable the app in the accessibility section in settings but when I get there there is no enable option, just like other settings in the accessibility section
this is an example: imgur.com/a/4rzQV
Someone can help me?
On most watches the accessibility menu is not even reachable, how do you get there ?
rush90
January 14, 2018, 2:53am
3
By the greenify initial setup
Jan 14, 2018 2:53:12 GMT 1 rush90 said: By the greenify initial setup
Can you do a screen capture ? For example, when my launcher asks for this section, i don’t have any issue selecting enable…
rush90
January 14, 2018, 9:44am
5
Jan 14, 2018 9:05:33 GMT 1 ricktop said:Jan 14, 2018 2:53:12 GMT 1 rush90 said: By the greenify initial setup Can you do a screen capture ? For example, when my launcher asks for this section, i don't have any issue selecting enable...
I installed your launcher and I try. Here is the results
i64.tinypic.com/2uh5uoh.jpg
i68.tinypic.com/2va08qd.jpg
i68.tinypic.com/2v3lys8.jpg
Jan 14, 2018 9:44:00 GMT 1 rush90 said:Jan 14, 2018 9:05:33 GMT 1 ricktop said: Can you do a screen capture ? For example, when my launcher asks for this section, i don't have any issue selecting enable... I installed your launcher and I try. Here is the results
You should switch to square mode.
rush90
January 14, 2018, 2:28pm
7
Jan 14, 2018 12:24:40 GMT 1 ricktop said:Jan 14, 2018 9:44:00 GMT 1 rush90 said: I installed your launcher and I try. Here is the results
i68.tinypic.com/2v3lys8.jpg You should switch to square mode.Square mode already active, is also seen in the images.
The accessibility settings screen is shown rounded, although the square mode is active.
Can I force the square mode in some way?
