Download: https://tinyurl.com/yxrzcdcj
Credit: https://i.gifer.com/AksR.gif Updated 11/12/2019!
Wow, very nice one! Thx for sharing!
Very nice indeed
. Thankyou
Wow it’s too good. Thank you @Edward for sharing this eye catching face.
@Edward I have to chime in with these guys Edward…it seems to be such a simple…yet thoroughly entertaining watch face. A very clever use of this 'Folding" technique.
Cheers, Doons
Thought this would be great on the Lem10 but when I installed it I only get a black screen with your logo showing in the bottom right hand corner. Possible to fix this?
Are you using Universal Launcher?
You will need universal launcher to see .gif files . Also i have not tested universal on square Lem10 yet .
Please let me know if it works LEM 10!
Dang! this took some time to make all the transitions! Very kewl! Thank you!
I installed the UL on my (16-1) Lem 10 and the watch face worked. But the UL was very unstable and even switched back to Main Activity on its own with out any input from me. I may try it again later. I have version 3.0.2 installed. I may try an older version that I run on my Les 1.
UL is NOT unstable at all. You must choose it as the default launcher.
I had selected it as the default launcher “always.” It was unstable on my watch. I may try it again using the same version I run on my Les1 and Lem 7 as a test. Except for this one watch face I have no problem just using the stock launcher which is very good.
It’s a neat concept, but I wanted a blue version so I made it. Here if anyone wants it:
@Edward, is this ok for you? Did he ask for permission?
Nope he didn’t ask, I live with it!
Next time please ask before.
DELETE DELETE DELETE! (just kidding)
Didn’t think I need to ask for permission. After all, I’m not claiming any credit, removing or adding new elements or posting it at another place–just modifying the color palette and adding it to the same thread because I wanted a blue shade for myself and thought someone else might as well. Perhaps it wouldn’t be amiss to point out that all rights belong to @Edward, but it’s pretty self-evident.
Dont worry . It was a genuine mistake to make . However all faces altered and re-posted - shared , however minor do require permission from maker . Thanks
