Hi everybody,
I search a good GPS apps for running with adapted interface for rounded watch. Do you know a good app for this ?
regards
Hi everybody,
regards
Aug 31, 2018 13:25:48 GMT 1 flagadajones said:
Hi everybody,
regards
Sense Me
also you can try Samsung Health
and this one is also good:
play.google.com/store/apps/details?id=pedometer.steptracker.calorieburner.stepcounter
there many good ones i use this one:Sense Me
Thanks for your anwser i have tested this 3 apps on my Watch ( DtNo1 K22) and it doesn’t work well… ![]()
i continue to search ![]()
which watch do you have? sadly if you meant no.1 D5 then i can understand, the firware is’nt great on these watches and Finow has’nt done anything to improve what they have on the other hand the firmware team that works with Kingwear, Lemfo, Zebalze, IQI, Microwear does a great job and so far i almost do’nt use square display for the apps.
Sept 1, 2018 15:08:24 GMT 1 soniasophie9697 said:flagadajones
i have this one no.1 K22:
en.001phone.cn/no-1-k22-android-smartwatch-heart-rate-wifi-message-notice-html
Sept 2, 2018 0:42:01 GMT 1 flagadajones said:
ok, i see, the problem that it runs Finow software and sadly they have’nt done any improvement in the firmware so most apps still do’nt work well with their watches.
Sept 2, 2018 8:59:49 GMT 1 flagadajones said:
Then any others rom is compatible with this Watch?
check this thread, they are working to get as much custom roms for these watches that it might, you better ask on their thread:)
Hi everyone! How are you
I just upgraded my allCall W1 to android 7 and everything goes great !!!
Since the battery life has almost doubled, but I’m looking for a fitness application that uses the heart rate sensor of the relog and that Once recorded the route with the GPS, before gliderun worked great on Android 5.1, but now gliderun does not work on Android 7, can there be an app that does this on a clock with Android 7?
Nov 8, 2018 20:52:15 GMT 1 axlander said:
edit: checked Gliderun and it works with android 7 and up, checked with lem x.
try HeartOnTop which syncs with google fit.edit: checked Gliderun and it works with android 7 and up, checked with lem x.
for my gliderun is preferred, but the application does not recognize the heart rate sensor.
Nov 9, 2018 16:25:19 GMT 1 axlander said:
