@Stephane_Etheve you are using a zeblaze, am I right?
no I use a lemfo les1
@Stephane_Etheve i know the problem from all zeblaze devices.
@Stephane_Etheve i have a lemfo lem5 and it’s working correct. Time is indeed running anti-clockwise and timezone isn’t relevant.
I’m on Amsterdam timezone which is the same as Paris. But if your watch can’t handle the anti-clockwise you will see a different time of course. For every hour from 12 o’clock your watch is going in the wrong direction. like mine say 15:00 yours will say 9:00
Not sure how to solve this because i cannot test it
@Israel_Gonzalez a black version is coming soon as i have the white one finished. Need to be sure that it’s working correct before i do the black one.
Not sure about the step counter though… only if it fits the minimal design
looks good on my Finow X5 Air
@Bart_van_der_Linden Maybe try the Tweaked ClockSkin export. There is a tweak in there that tries to solve this problem of rotating backwards on some watches, by creating an empty layer to switch directions…
good afternoon in my lemfo lf16 does not mark well the time goes with 8 hours in advance
white and black version available:
https://plus.google.com/u/0/110573365824811038152/posts/AC9VPaQZ9dS
@Marco_Ferreira thats sounds interesting. Is it possible to re-import this clockskin and try the tweaked clockskin-export?
There is already an empty layer inside…
Don’t think you can re-import because it’s a custom .xml
You can try of course
@Bart_van_der_Linden I have the exact same problem with my own version. Btw:
Your scale is better…
Thanks for a very nice minimal design. A “simple” solution to the problem some watches (incl. my Zeblaze) has with counter clockwise could be to make the center to the right instead of the left side of the watch so the rotation will be clockwise.
It sounds simple but I’m aware that you need to redraw the full circle with hours and minutes. I hope this will not be to much to ask please?
@Johannes_Bang_Jeppes and others.
in the LEM5 Faces section there is a black clockwise version to test if this is working for you
@Bart_van_der_Linden Thanks a lot. This looks nice and works almost perfect. I just had to add 200 to digital3 array in the clock_skin.xml file to align the battery indicator correct on my watch…and then copy a few white images from your white version to make a white clockwise…hope you don’t mind ;o)
@G1NT0N1C It’s not yet possible to import this watchface on WFD because WFD doesn’t support (yet) these large images. However, I’m in the process of changing it to start supporting them. The sliders change on version 0.11.0 was the first step on that goal
@Johannes_Bang_Jeppes I don’t mind… most people want a dark watch face for battery so i did that first.
Nice that you have it working
@Bart_van_der_Linden one small thing I discovered today. The shadow is from the counter clockwise watch so at 16:00 the shadow shows 08:00. Again easy to fix myself. But the big work you have done making the clock numbers I don’t have the tools to do. I am extremely thankful for that.
PS with my old watch I was also most into black backgrounds because it had a black border around the screen but now when I have edge to edge screen I dare to use other background colors and I think your numbers and especially the shadows is more clear/sharp and elegant on the white version.
It didn’t work properly on my Zeblaze Thor ,the time now is around 11pm but it is showing 1pm?
@Bart_van_der_Linden I can (and did) recreate your watch on WFD (on the developing version. I use your watch as a test to large images support
) and made it clockwise for those watches that can’t display it counter-clockwise. I just do not know which font you used. I’ve also added two tweaks to the tweaked clockskin export to solve some of these problems, namely the battery location and the second counter-clockwise layer (some watches interpret direction as maintain/invert while others interpret it as clockwise/counter-clockwise). I cannot, however, solve the issue of some watches not supporting counter-clockwise rotation on 24h mode. The only fix for that is installing Eric’s Universal Launcher, or wait for a better firmware…
