A great looking watch, but setting 24 hour rotation to quartz doesn’t work on my Prime… Indications, therefore, of the city codes do not rotate correctly (except in WFD).
CREDIT: Glashuette-Original.com
Which version do you use? Sometimes it wont work on 14 but works on 14 beta. I had the same problems with my last naviforce rotating the days correctly… solution: try to adjust the starting angle till it fits. Made a change in wfd loaded in watch to check if its working, back and forth till it does. Cheers
Genius! That did it!
Interestingly enough, one or more of the moderators warned NOT to use WFD Beta (something about its still being in development).
Thats why i use both now. Ur welcome.
It’s ok to use this beta. However, there are functions that work in the normal version, but not in the beta. Take it for what it is: an early beta version.
Thank you for the clarification
