Hi, i am so dissapointed with my Thor Pro, but i eill give it a last chance.
How can i flash my watch with the latest Firmware?
Tutorial is on our YT channel.
Oct 8, 2018 12:18:41 GMT 1 grisu63 said:
guys, 1.have you made sure to disable sync and updates of google apps 2.try not to use wrist geture and only vibration or sound or both i do it:) and i have the lem x. 3.you need to understand that there are apps that uses wifi or 3g if they always on, also if wifi and 3g are on and they connecting is weak then that can have an effect on battery life. 4.from my exprience battery behave way better when charging the watch when it is on never let it get under the 5% and discharge it when reaches the 100%. 5. flashing the watch and using upgrade aslo helps improving battery life. 6.final solution is rooting and monitoring the battery usage with Wakelock Detector.
