i have a zeblaze thor and today i tried to flash last firmware but… by mistake i flashed the lemfo lf 16. When i turned on the watch display is black and i cant see nothing.
Now i can not flash the right firmware because the watch is on and the flash process dont start.
that is a problem because most likely the preloader was marked, you have to disconnect the battery or wait till it drains itself and flash the right rom, do'nt flash an update but the stock firmware rom.
I have similar problems, I get an unknown peripheral is connected and not flash the rom the watch vibrate if old button for more time the sensor in the back flash, but the display stay black
Either wait for battery to drain or disconnect battery for a while then reconnect and flash again with proper firmware.
Remember that you first click on Download button in SP Flash Tool and then connect watch to computer
Well next time before you trash something like that poke me I’ll gladly act as a trashcan
From my own experience I know that’s not that easy to hard brick those watches.
Did you try doing what I wrote?
